a can tpms? j tyre the be replaced valve astra replacing without
Astra J. Can a tyre valve be replaced without replacing the TPMS?
I have an Astra J hatchback, 2015 reg, I think it is “pre facelift” but not sure.
It has slow punctures on both off side wheels
My tyre garage (Formula 1 Autos) told me that air is leaking from between the valve body and the alloy wheel seat.
They say that if I can get hold of replacement valves they will replace them. They say that this will not involve disturbing the TPMS.
Are they correct?
Is the TPMS separate from the valve on this car? All I can find are combined TPMS and valve units.
Is it worth just screwing the nut down a bit?
I have heard of “screwed type” and “clipped type”, TPMS which type do I have?
Do I have manual learn or auto learn?
I have attached images of
1. Mine in place
2. Version A available on internet looks like mine
3. Version B on internet. Is this the same as A but with the securing nut removed?
4. Valve only, with no tpms, is this designed for my car?
A large reputable local tyre fitter, Micheldever Tyres, have a universal tpms device called an i-smart, does anyone know anything about this brand?
p { margin-bottom: 0.25cm; line-height: 115% }
Vauxhall had 2 different sensors at the time a brown https://smile.amazon.co.uk/Schrader-3026...-chr-uk-21
These were succeeded with the one's you have in the 3rd pic
https://www.vxoc.org.uk/forum/attachment.php?aid=1177
If you have the black one you need these
https://www.ebay.co.uk/itm/Replacement-T...SwF3BeXh-A
If it's just the Nut you can replace just that part, part number is 24455308
In the end local Kwik Fit said they could replace just the valve stems for £20 per wheel, job done, but will wait until I am sure the slow punctures are fixed
Admin, I couldn't find where to type in the quick reply section, cursor didn't register
Admin: Now I found it!
  High pitched noise (Astra OPC J) maximame 0 4,476 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 5,311 22:nd-Feb-2021, 08:08:37
  tpms fault badger64 2 1,828 3:rd-Dec-2020, 21:44:51
Last Post: badger64
  Astra GTC auto gear knob replacement Jayrich872001 12 20,528 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra J SRI 13 Plate - Radiator Fan Gavin1506 2 3,835 11:th-Jul-2020, 22:08:04
Last Post: Gavin1506
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 5,466 1:st-Mar-2020, 22:27:38
Last Post: _Mita
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 2,821 20:th-Feb-2020, 19:32:31
  shock absorber noises astra j blacknik 1 4,755 10:th-Feb-2020, 08:34:15
  Noise when clutch 1/4 depressed 2013 Astra J Galway11 0 8,028 27:th-Jun-2019, 22:40:04
Last Post: Galway11
  Astra j radio / display problem Trublu24 6 16,471 1:st-Feb-2019, 08:38:04
