issue j astra headunit
ASTRA J HEADUNIT ISSUE
I have a aftermarket head unit installed never had a issue for 2 years(was pre installed before purchase), its a Driveaudio Premium V2 with a cd400 stereo unit. Today I had installed some canbus led light bulbs, kept getting errors so have removed them since. I didn't realise until I needed to use my headlight that every time I turned my headlights on the rear camera would come on but says on screen no signal (camera works as should in reverse gear). I've disconnected the battery for about 15mintes but that didn't fix the problem. I'm just wondering if anyone has any suggestion to help fix this, maybe a fuse or relay but don't know where to start.
Thank you for any helpful advice.
Did you touch anything in regards to the radio?
Are all the lights working?
  DRL - sidelamp issue stajerad 1 2,093 12:th-Sep-2021, 15:37:54
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,503 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 7,990 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,499 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,767 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,844 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 1,982 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,105 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  DRL/Sidelight Issue MassiveRoy 1 2,044 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
  Astra J GTC PDC bracket milozic 5 2,435 2:nd-Feb-2021, 09:39:35
