Please note we be moving to a new server, this will happen sometime Thursday onwards. If there is any downtime please rest assured we will be working hard to fix it and keep it to a minimum. Thank-you for your support. (July 12)
fit reversing camera on astra j gtc
Hi everyone could you tell me which head unit i need to put a reversing camera in..also how to install it please. Am sure someone on here said that a navi 600/650 is able to fit the camera in. but cannot remember thanks mal
Could be also CD600 (I've done it on my previous J).
600/900 & 650/950.
I make the looms, the radio will need to be programmed also.
(11:th-Feb-2019, 09:02:33)Rusty2009 Wrote: You are not allowed to view links. Register or Login to view.600/900 & 650/950.
hi could you give me any more info as your alittle to far to travel to....if my radio is already programmed to my car does the camera wire up to  it or does it need extra kit??? do you have any wiring diagrams please
The radio needs to be programmed for rear camera to function. this will need to be done via a VCI code and SPS.
Looking at fitting reversing camera on my 2015 Gtc vxr.
Navi 950 with Infinity factory fitted.
What do I need please?
You are not allowed to view links. Register or Login to view. is you man for this one chap.
(8:th-Jul-2020, 19:33:06)iandy66 Wrote: You are not allowed to view links. Register or Login to view.Hi
The radio needs programming to know it has rear camera (Which I can do via the post) you will also need a rear camera and loom (I make custom loom & do have a stock of cameras)
As your Norfolk way I guess you wouldn't be willing to travel to Bournemouth.
The bumper will need to come off to run the camera loom, while the bumper is off you can cut the hole for the rear camera.
Sounds good
Can you give me a price I will have ago at doing it myself as Bournemouth is a bit far!
Cost to program the radio supply loom and camera would be £160.
That will also include all Radio updates which are needed from SPS via USB & 2018 Map (the last ever Map update for these units).
Turn around time is normally 1 day as the updates take some time to apply.
Ok
That’s Great, I was thinking of using the Camera that comes with the Number plate light what are thoughts on these
(9:th-Jul-2020, 10:37:42)iandy66 Wrote: You are not allowed to view links. Register or Login to view.Ok
better with a factory camera sits centre of bumper rather than to one side.
Ok I’ll do that then.
How do you want me to pay you?
I always ask for payment once radio box is programmed and ready to be sent back, Payment via Bank transfer is preferred.
Can PM me if you want to go ahead and we can go from there.
Hi Rusty, I'm Matteo from Italy.
I've an Astra J GTC 1.6 Turbo petrol MY12 with NAVI900.
I've tried several times to obtain VCI code by GM but unfortunately is not available (for my car).
In your opinion is possible send you my NAVI900 unit in order to program it (and unlock rear view camera function)?
Actually my unit is updated with SW V.2.08 and custom red theme (will they overwritten/deleted?).
Thanks in advance.
Regards, Matteo.
Hi Rusty2009, I activated the feedback with cd600 vci code, but when I switch from r to d, the screen immediately turns black and the vision is gone. I got the OEM Camera feed from the reversing lamp, where do I need to get the camera's energy for delayed camera switching. I'll be glad if you tell me your method, thank you.
(2:nd-Dec-2020, 20:24:24)Morpheus75 Wrote: You are not allowed to view links. Register or Login to view.Hi Rusty, I'm Matteo from Italy.
Thanks in advance.
Regards, Matteo.
No GM will refuse the GTC as rear camera was never an option on them for some reason.
I don't have any sources for Italy's cars to use a work around.
In terms of the themes no etc no they do not get overwritten when reprogramming.
(6:th-Dec-2020, 11:35:36)ayhansecil Wrote: You are not allowed to view links. Register or Login to view.Hi Rusty2009, I activated the feedback with cd600 vci code, but when I switch from r to d, the screen immediately turns black and the vision is gone. I got the OEM Camera feed from the reversing lamp, where do I need to get the camera's energy for delayed camera switching. I'll be glad if you tell me your method, thank you.
Depends what camera you have fitted.
Hi Rusty2009, I enabled feedback with cd600 vci code but when I switch from r to d the screen immediately goes black and the image disappears. I got the OEM Camera feed from the reversing light, where should I get the camera's energy for delayed camera switching. If you tell me your method, I would appreciate it, thank you.
It depends on which camera you have installed.
I am using an oem camera. which camera would you recommend to use for original connection
(8:th-Dec-2020, 06:52:36)ayhansecil Wrote: You are not allowed to view links. Register or Login to view.Hi Rusty2009, I enabled feedback with cd600 vci code but when I switch from r to d the screen immediately goes black and the image disappears. I got the OEM Camera feed from the reversing light, where should I get the camera's energy for delayed camera switching. If you tell me your method, I would appreciate it, thank you.
On the OEM camera there is a run crank wire this goes to the rear fuse board (you may need to swap out the rear board as some don't have the fuse or pin needed).
Of course if there is no rear fuse board then you run to the glove box fuse board and do a piggyback.
Rear fuse board X1 pin 33 (there maybe a wire in there in which case splice to it).
Glove box fuse board you can piggy back off fuse 21 & use a 2AMP fuse for the camera.
Please not the wire colours are for my own custom rear camera loom.
but follows to the following on the OEM camera
Pink = Red Run crank (Pin 6)
Blue = Yellow Camera signal +2 (Pin 1)
White = White Camera signal 2 (Pin 4)
Black Heat shrink = Black camera wire drain (Pin 2)
Orange = Green Reverse light (Pin 3)
Black = Black Ground. (Pin 5)
[Image: Rear%20Camera%20Wiring%20info.png]
Thank you, so are you confirming that on the GTC it will not be possible in any way to activate the rear view camera?
(7:th-Dec-2020, 08:42:29)Rusty2009 Wrote: You are not allowed to view links. Register or Login to view.
Thanks in advance.
Regards, Matteo.
(30:th-Dec-2020, 20:11:17)Morpheus75 Wrote: You are not allowed to view links. Register or Login to view.Thank you, so are you confirming that on the GTC it will not be possible in any way to activate the rear view camera?
It is possible but not with GM, I've done a load of GTC's / VXR's.
(31:st-Dec-2020, 07:37:13)Rusty2009 Wrote: You are not allowed to view links. Register or Login to view.
Can you explain me how to? (by P.M. please)
Hi, I have just fitter the camera on the Navi 950, data wires taken as described 5 and 15.
Ground and Rev Light both taken directly from the rev light cable itself.
And Run Crank taken from the front lighter - don't have the rear fuse box and wasn't aware how to take it from the front fuse box, until reading it here just now.
Everything is working fine, I'm just wondering if there could be a potential problem with the lighter wire taken as Run Crank?
Possibly Related Threads...
  Rear view camera MarkAP68 0 0 25:th-Jul-2021, 13:51:03
Last Post: MarkAP68
  ASTRA J OEM PARKING SENSORS blacknik 15 0 3:rd-Feb-2021, 19:58:42
Last Post: Qaranc
  Factory Reverse Camera, Astra j/GTC, insignia tucpal 27 1,512 23:rd-Aug-2020, 08:48:59
  How to retrofit flex floor Astra-J (MK6) 5 Door Rusty2009 11 6,185 18:th-Feb-2020, 08:13:37
  Astra J Sport tourer and OEM rear view camera saarits 47 2,421 26:th-Mar-2019, 23:38:23
Last Post: tzr608
  Retrofit Rear Power point 5 door Astra J Ballinlea 3 0 20:th-Mar-2019, 18:13:44
  Astra gtc retrofit foglights Daniel199025 1 0 19:th-Jul-2018, 07:32:40
  astra j gtc bluetooth tucpal 19 9,885 18:th-Feb-2018, 12:54:24
Last Post: Dooks
  Astra J 11 Radio Upgrade Dolenc 1 754 14:th-Feb-2017, 07:47:16
  astra j 2011 mayo89 1 773 4:th-Sep-2016, 16:44:00
