Zafira c - Shift knob not returning
Hello to all.
I have a 2012 Zafira C (Tourer) and started to have a problem in the shift knob.
The shift drives normally for shifting gears, but the gear does not return to its original position by itself.
Same as this video : You are not allowed to view links. Register or Login to view.
Can anyone help, or already had this problem?
IS there an "easy" solution for this?
Thank you
Once in while mine does this no idea why lasts for 5mins or so then goes back to normal.
You are not allowed to view links. Register or Login to view. may have an answer.
Thank for your reply @Rusty.
Well mine has being doing this for a while now .. a few months i guess.
Its just really annoying, and i was wondering if :
1- Is is expensive to resolve
2 - left like this will bring later bigger problems .
J.
Hi have you tried removing the gaitor and greasing the linkage if its like my GTC its a nylon ball and the greese dos dry out used some spray grease on mine not for your problem but just the general rubbish gear change did help a bit like everything Vauxhall they where a bit tight on the lube front
(30:th-Jan-2019, 11:29:05)andyp Wrote: You are not allowed to view links. Register or Login to view.Hi have you tried removing the gaitor and greasing the linkage if its like my GTC its a nylon ball and the greese dos dry out used some spray grease on mine not for your problem but just the general rubbish gear change did help a bit like everything Vauxhall they where a bit tight on the lube front
Thanks for your help.
Unfortunaly i'm not a mechanic, but will bring that information near a known mechanic of mine.
J.
probably needs the gear linkage adjusting, which does not take long to do
(30:th-Jan-2019, 18:01:59)vocky Wrote: You are not allowed to view links. Register or Login to view.probably needs the gear linkage adjusting, which does not take long to do
Hello.
Does that job needs a qualified mechanic to perform? Or is it someone can do with youtube or something?
J
If you have an F40 gearbox: You are not allowed to view links. Register or Login to view.
(30:th-Jan-2019, 22:47:06)Telsun Wrote: You are not allowed to view links. Register or Login to view.If you have an F40 gearbox: You are not allowed to view links. Register or Login to view.
Hello.
How cna i tell wich is my gearbox?
I have a 2012 Zafira c, 2.0Diesel
Think it says in your handbook
(31:st-Jan-2019, 17:00:22)Telsun Wrote: You are not allowed to view links. Register or Login to view.Think it says in your handbook
Ok.
 Thank you for your help.
Will look into it
Thnkx
J.
What engine do you have?
(1:st-Feb-2019, 08:31:57)Rusty2009 Wrote: You are not allowed to view links. Register or Login to view.What engine do you have?
Hi there.
Its a 2.0 diesel, i think 165 hp
Thanks for any help
J.
Then you should have the F40 gearbox.
(2:nd-Feb-2019, 09:10:28)Rusty2009 Wrote: You are not allowed to view links. Register or Login to view.Then you should have the F40 gearbox.
Thanks.
Going to check the llnk above.
Possibly Related Threads...
  zafira gsi alternator zaffydom 0 610 27:th-Jul-2016, 15:54:48
Last Post: zaffydom
