Rear brake pads and discs
Hey Guys
I have an Astra GTC 62 plate 1.7 diesel.
I need to replace rear brake pads and discs. I'm looking on Euro car parts and there are two types of discs and pads. Is there anyway of knowing which pads and discs are correct short of measuring it all and buying numerous variations?
Thanks. Any help appreciated
Info obtained from another Astra forum
Rear brake discs: 292mm
(except VXR: which are 314mm)
ECP should be able to tell you what pads relate to this size of disc.
Having had a quick look on You are not allowed to view links. Register or Login to view. the parts are cheaper than from ECP.
(21:st-May-2019, 11:31:21)Big Dave2 Wrote: You are not allowed to view links. Register or Login to view.Info obtained from another Astra forum
Thanks davw really appreciated it.
Dabe you don't happen to know this info do you :
Does anyone know the:
1) Torque specs: Brake caliper bolts
2) Torque specs: Caliper Bracket bolts
3) Torque specs: Wheel bolts
3) Winding back rear calipers : Clockwise or anti clockwise
Pretty sure most of the answers to your question are here
Possibly Related Threads...
  Front Brakes + Discs sizing everson38 3 0 12:th-Aug-2019, 10:53:27
  electric rear windows marky79 5 0 11:th-Jan-2019, 09:04:32
  Rear Light Replacement (Need Advice) A.ROD 2 0 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  GTC water collects under rear window Canasta 2 0 30:th-Oct-2018, 22:23:04
Last Post: marky79
  Jolt when releasing brake on autobox Djones55 3 0 21:st-Oct-2018, 10:42:34
Last Post: Canasta
  Headrest for middle rear seat passenger benawhile 7 0 12:th-Oct-2018, 07:10:57
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 2,715 26:th-Sep-2018, 23:50:59
Last Post: everson38
Sad Rear electric windows & front fogs problems... Griifter 18 0 30:th-Aug-2018, 20:01:30
Last Post: Griifter
  Rear window Mspencer 3 0 10:th-Jul-2018, 03:58:40
Last Post: Mspencer
  Brake bleed nipples? Jake 4 0 27:th-Apr-2018, 18:36:07
Last Post: Jake
