DPF REGEN LIGHT
#51
(14:th-Jan-2017, 17:59:38)Astra VXD Wrote: You are not allowed to view links. Register or Login to view.I never get a regen light come on. One way to no is put your cars trip computer into instantaneous fuel consumption.on tick over it should be 0.2 if you find when u come to a round about or junction it is displaying 0.4 you no your car is trying to regen,never turn off engine if 0.4 is displaying, last time I done that the next time I started my car it went into limp mode and had zero power.keep revs 2k or over until your revs drop.
But installing the Led gives an instant warning which if your driving is great as you can't check the fuel consumption
My experience: when I put the foot of the throttle pedal the instant consumption should drop to 0 mpg. If not then I switch the trip computer to section ECO and under top consumers the rear defroster is listed but on the dash board ther's no light at the rear defroster button. When the rear defroster disappear from the list the DPF regeneration cycle is finished.
Some models don't have the eco menu on the dash
and it is not so good just to have top consumers on all the time just incase it does it
I agree with you both.
The LED seems to be a good idea.
Thumbs
Lightbulb
This is how mine looks when it is doing a regen.
[Image: dpf%20image%201_zps2ddo8alo.jpg]
This is how mine looks when it is finished doing a regen.
[Image: dpf%20image%202_zpsstgu0jcr.jpg]
Happyblue module, right?
Yep..
Is it normal to get the "backscreen defrost" for the first 5 miles of almost every journey? I'm waiting for my happyblue to see in more detail what is it actually doing but still that's pants as I've got around 6 miles to the nearest motorway to rag it a tat.
(11:th-Apr-2017, 09:35:01)Nuko-san Wrote: You are not allowed to view links. Register or Login to view.Is it normal to get the "backscreen defrost" for the first 5 miles of almost every journey? I'm waiting for my happyblue to see in more detail what is it actually doing but still that's pants as I've got around 6 miles to the nearest motorway to rag it a tat.
If it comes from start it's not doing a regen, if you rev above 2k revs it will turn off.
Look in the settings menu (accessible via the stereo buttons) and see if you've got the rear screen to automatically come on.
It does finish whatever it's doing after that distance, I've done it a few times - it does stay on when I rev it up to around 2200 rpm, going above that will turn it off but then when the revs go back to the range (idle - <2200) it's back on. It's silly to do that every time - sit in the driveway for 5-10 min and rev it, should have gone for the pertol  Thud
(11:th-Apr-2017, 10:52:46)Big Dave2 Wrote: You are not allowed to view links. Register or Login to view.
??? it's not the rear screen heating that's on mate
You are not allowed to view links. Register or Login to view. is right.
In the Settings menu under Climate and air quality -> Auto rear demist you can choose on or off
Page 134
(11:th-Apr-2017, 12:50:24)Jerry Wrote: You are not allowed to view links. Register or Login to view.You are not allowed to view links. Register or Login to view. is right.
Page 134
Fair enough - will have a look at that, don't recall seeing it before, I do apologize Big D. :-)
No option like that, just checked
I have disable the "Auto rear demist" option and i realize that this comes on for a couple of minutes when the outside temperature is over 18-19 degrees and not below.It's a good function but i think that the operation is a bit opposite of that would be.I think that the thought of opel is to avoid the moisture of breath to the rear screen which happens when we enter to the car with low temperatures or rainy outside conditions but the whole function seems to have bugs.
Has anyone tried running BOTH the mirror and the switch signal through an XOR made out of transistors & resistors to make this function a little better?
Basically, if you switch on the rear/mirror heaters manually, both the switch & the mirror lines will be live, resulting in the XOR returning false and NOT lighting the regen LED.
If the regen switches on the rear/mirror heaters by itself, the XOR will return true and those lovely electrons will light up the regen LED?
Ordered some 2N2222A anyway and will give this a bash, worst case scenario I've wasted a pound and some time.
No I hadn't even of thought of something like that, plus it's out of my area.
I would be very interested though as it sounds a great idea.
Great thinking Umognog!
Please let us know what you come up with Smile
If it succeeds I'll look into a how-2 + potential pre-made plug in project boxes for the lazy/out of their depth folks (appreciate doing these kind of things is not for everyone.) Premade boxes however may be difficult depending on how I can tap into the manual button push.
You got me thinking about it and I think I found a flaw in the plan.
Correct me if i'm wrong but the way I see it:
You can make it work so that the DPF light won't come on if you use your heaters.
But you can't make it so that the DPF light will come on when you use your heaters AND the DPF starts to regen at the same time.
So that will be a setback.
What you described can be done with a simple 12v relay I think. Hardest part will be getting the wire from the heater button to the Led and relay Smile
I drew a simple diagram of how I see it:
[Image: ZFPLyi6.jpg]
I'm not that great with electronics so maybe you do know a way to get it to work both ways?
But I don't think you can because you can't know if the DPF is regenerating while the heaters are on because you use the same signal. If DPF regen starts when heaters are on nothing changes on the wire to the heaters. The heaters are on and stay on when DPF regen kicks in.
EDIT: oh and then there's the auto demist function which wont turn on the heater button either which might give a false positive anyway.
You are right, if you are already using the heater & the dpf regen starts, the xor = false would apply.
It is the biggest issue of software controlled services: it's a single common wire to heat the mirrors, it's software telling it to switch on and off. Without being able to directly interface the software via a supported API for example, it's not possible to know for sure.
That said, if you follow the current how to, manual de-mist + regen you wouldn't know anyway as both have the light on regardless.
At least this would switch the light off when you are pushing the button, removing 50% of the false reading options you have.
As to connecting, this may be where it's a do it if you dare, taking a sink off of the switch led and running it with small hookup wire. It may not be pretty.
Lastly, might try to read some info with an OBD2 BT scanner and an ATMega 328p with a BT module. This is more technical & more expensive and a further iteration on improving it.
Yes the issue could be all the commands are done via canbus as there is only the one wire on the heater panel which does every button.
You may find you'll have to try and intercept them signals & see what is going on. Sure You are not allowed to view links. Register or Login to view. could explain that.
That's my thoughts You are not allowed to view links. Register or Login to view.
Depending on the communication method (really hoping its something simple like serial) it could be as easy as a £1 microcontroller and some python to read it & control the LED but this gets way more complicated than a simple XOR to stop it going on when the human pushes the button, which I could tap into the button LED for the NPN
Ok, I went down a rabbit hole.
I now have a canbus shield ordered and will be making a logger. Pretty sure from what I have found out it will be running on MS-CAN.
Once I isolate the logs for the data needed, should be able to make a plug and play box that simply connects to the centre console as a plug-through system. The final product can run off a simplified MCP2515 and atmega 328, keeping costs lower.
I dunno if it can be found on the mid speed, I planned to sniff on the hs but I got quite the backlog of stuff I want to do.
The gmlan bible doesn't have a CAN id for it either so no joy there.
What resource hinted that you would be able to find anything on the MS lan?
Also, how do you plan on toggling DPF regeneration while logging?
You give me much too credit good person
The rear demist switch should be on the MS - I am led to understand the entire centre console is. This was to trap user-initiated demist as my original intended way to not switch on the led
Little bit more thought after a few tins of monster and yes, if I want to try catching the regen I will probably find that on the HS, however I suspect it is communicating with the LS and/or the MS through the CIM/radio unit.
I actually ordered a triple pack, might data log them all and the plan is to simply drive around with the standard regen LED mod, capture the time and disconnect the loggers once it goes off.
That's not a bad plan but it'll be pretty tedious. If you haven't looked at either bus so far, it might be a bit overwhelming. There's a ton of messages being passed around. Don't expect to find what you're looking for without some rigorous filtering set up. On the HS bus the traffic volume is too high to simply log over serial. Longer periods of logging would require an sd card.
I'll see if I can force a DPF regen over MDI. If so, it'll be much easier to track precisely which messages are relevant.
Apparently the happyblue module can show this, so we can also look at the firmware on this device but my guess is this'll be even more tedious.
Had already thought to log to SD card. I'm a data developer for a living, have a number of tools at my disposal to help deal with the output Smile
Well thanks for all the help just done mine this morning....
I placed the led on the removable top cover found this easier.
I was just talking about the regen yesterday: typical to cover over 1000 miles on the motorway across a couple of days, to then get a regen during a short journey!
Life has been quite upside down for me recently, need to get back on the one-wire data logging and start analysing it.
Possibly Related Threads...
  Rear Light Replacement (Need Advice) A.ROD 2 0 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Help engine light Mspencer 12 0 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
  No wiring for the interior boot light marcus01 5 0 20:th-Dec-2017, 16:48:23
Last Post: rlievens
  Rear fog light bulb ID jl47 0 0 15:th-Dec-2017, 15:24:34
Last Post: jl47
  Airbag light always on? Ssss 12 338 5:th-Oct-2017, 10:50:28
  Faulty back light Jon3sy 4 339 24:th-Aug-2017, 17:04:11
  Astra 1.6 Turbo Engine light P0171 abba34 1 314 7:th-Aug-2017, 04:21:09
Last Post: sanj424
  led courtesy light drivers door twinpipes 1 360 4:th-Jul-2017, 06:49:12
  DPF Regen question SectorOMEGA 11 842 12:th-Jun-2017, 12:38:51
Last Post: sotoskon
  Astra light in footwell Jon_es 2 611 4:th-Apr-2017, 22:14:39
Last Post: Tonto
