Astra j radio / display problem
Hi, apologies if this has been asked before but i cant find any treads about it. I have a 2010 Astra J which recently had battery problems. I had to jump start car recently before replacing the battery. After jump starting it the radio and display stopped working along with the indicators working but with no sound?? I have checked wiring behind radio and display along with all the fuses but can't find anything wrong? I have searched online but can only find a Youtube video in which another person has the same problem but no remedy? If anyone could point me to a tread about this or has any ideas as to a remedy i would be grateful. Thanks
The jump technique you used might have upset the canbus network.
Did you follow the correct procedure in the handbook?
Try disconnecting the battery for ½ hour or so to allow the car's brain to reset. You'll have to program the elec windows afterwards - instructions in thehandbook, but you won't need a code for the stereo.
Hi Big_Dave2,
Thanks for the reply and the info ??
Didn't know there was a correct procedure for jump starting, I should have checked the hand book for that one, thanks for the heads up.
I'll give the battery disconnect a go and let you know how it goes.
Thanks again for the reply, much appreciated.
Disconnected battery for 1hr+ but no joy. Probably fried something when jump starting the car? Have car booked into main dealer for next Wednesday hopefully they can sort it and it won't cost an arm and a leg...
Thanks for your help.
(7:th-Nov-2018, 17:00:53)Trublu24 Wrote: You are not allowed to view links. Register or Login to view.Disconnected battery for 1hr+ but no joy. Probably fried something when jump starting the car? Have car booked into main dealer for next Wednesday hopefully they can sort it and it won't cost an arm and a leg...
Hello
Have the same issue, but I didn't have weak battery. Did You fix it and what was the problem?
Thanks in  advance
this probably doesn't help,
but
I jumped my tourer quite a few times (with a jump pack) before I finally got a new battery
I've never had the radio fault as described above and my indicators were always quiet (strangely they started clicking loudly after Rusty coded the radio for DAB and rear camera)
(30:th-Jan-2019, 20:43:33)niteram Wrote: You are not allowed to view links. Register or Login to view.this probably doesn't help,
but
There is a setting for warning sounds low or high. check that setting.
Possibly Related Threads...
  Astra GTC CD 600 Blutooth will not delete devices harrykelly9 2 0 24:th-Oct-2018, 21:52:47
Last Post: harrykelly9
  Astra J 2.0 cdti noise on cold start up Iaintruten 3 0 17:th-Jan-2018, 17:26:31
Last Post: Iaintruten
  Astra GTC auto gear knob replacement Jayrich872001 8 0 5:th-Jan-2018, 12:15:49
  Corrosion on underneath of Astra irishastraowner 4 369 19:th-Sep-2017, 10:57:12
  Outside temp display Chaddyowl1973 1 376 27:th-Apr-2017, 09:39:06
  MAF Mass Air Flow Sensor is this common problem caretaker 3 1,454 21:st-Aug-2016, 19:42:18
  ASTRA J CONDENSATION IN FRONT AND REAR LIGHTS! LukeAstra15 7 2,196 9:th-Jan-2016, 18:45:36
  Astra J 1.7 engine chirping and pressure Jasoncourt 13 3,333 11:th-Sep-2015, 07:25:07
  Name Display When On Call Lewis6317 4 1,537 1:st-Aug-2015, 19:58:52
Last Post: J1ODYA
  fan blow problem ozzysastra 7 1,874 31:st-Dec-2014, 09:52:28
Last Post: Lewis6317
