2014 Astra 2.0L 165 HP F40 gearbox quantity of oil??
  • Hi all,
I have searched around on so many forums now and unable to find a definitive answer as I have heard rumours of vauxhall overfilling the F40 gearbox so I have heard it holds 2.4L, 2.6L, 1.9L, I dont have a clue how much is in thereor whether should be putting in less than what I get out because that what I have seen on a few forums. Would really appreciate some guidance on this!! All I do know is I will be using Redline 75W-85 GL04 oil for it... but how much of it??? ??
Thanks for the help!
Vauxhall normally have a drain and fill bung so you used to drain the oil put the bung back in and refill through the fill bung until it starts to dribble out. Don't know if that has changed though for F40 box
NAVI950 , DAB+ , Rear Park assist & Rear Camera retrofit Smile
F40 drain from the bottom fill from the top.
I've not heard of anyone complaint about the F40 box being overfilled under filled. Yes plenty of complaints about the M32 being overfilled and under filled.
In terms of the way to go drain out into a measuring jug and refill with the same amount that has come out. You will not get all of it out so this would save you over filling it.
It's how mine was done not had any issues.
Ah just read this lol, did it about 3 or 4 days ago... got out 1.7L and filled up with 1.9L..
Reckon that'll be problematic? could always use a little hand pump to siphon 200ml out
Thanks for the advice
Possibly Related Threads...
  Astra J 1.6cdti ecoflex lowering Alan300589 3 0 18:th-Feb-2020, 19:27:25
  astra j limp mode mark7 0 0 10:th-Feb-2020, 19:52:30
Last Post: mark7
  astra j 2.0 start up cornwall37 1 0 10:th-Feb-2020, 08:36:14
  Which wheels and tires Astra J 1.6 CDTi 110hp _Mita 1 0 31:st-Jan-2020, 09:38:19
Last Post: _Mita
  Astra GTC Exhaust Eve26 1 0 20:th-Nov-2019, 18:26:24
  Astra/Meriva hubs for new alloys hooper 3 0 10:th-Nov-2019, 08:34:35
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 0 10:th-Nov-2019, 08:31:13
  Astra j vxr front seat Custerz90 7 1,079 31:st-Oct-2019, 16:30:42
Last Post: marablind
  How to change Astra j fuel flap mechanism? Amazingusername 2 0 11:th-Oct-2019, 12:56:58
Last Post: Amazingusername
Wink F40 gearbox oil amount Wak1969 6 0 3:rd-Sep-2019, 18:21:46
Last Post: Wak1969
