2.0 CDTI GTC rear springs
I have a 2.0 CDTI SRI GTC and today noticed one of my rear springs has broken, so it's time to replace them both. Does anyone know the part number for the rear springs on the GTC, and if they are the same as the 5 doors? I am right in thinking that the SRI springs are shorter than the standard ones, aren't I?
Links to buy the springs would be even better! Just after GM or OEM spec springs, nothing that would lower the car.
Thanks!
Hi, yes SRI springs are 10mm shorter.
Have a look on You are not allowed to view links. Register or Login to view. put your reg in and look at the springs on there, there is a discount code for 58% off WKD58.
But please double check it by putting your reg in you'll get the 2 for £65.
Thanks for the link and discount code.
That part does seem to fit based of my reg but GSF also shows another spring (Part No. 511GM1450) that will fit my car. Now if I don't put my reg in, and instead choose the make, model, year and engine, it doesn't mention the SRI as a separate category anywhere in the lists, so the I imagine one spring will be for SRI and one will be the longer springs?
Is the link you sent me for the shorter SRI springs?
I believe it is yes. the only difference I see between the 2 is the price.
I fitted the ones I link to above on my 5-door and it was the shorter one.
If in doubt they have a live chat in bottom right just ask they are very helpful.
Perfect, if they're good enough for you I will just get them ordered. Will report back if I have any problems.
Possibly Related Threads...
  Rear registration lights LegendOfEagle 2 0 7:th-Feb-2019, 17:42:57
Last Post: LegendOfEagle
  Rear lightning cable color question DaanV 6 0 26:th-Aug-2018, 15:51:11
Last Post: DaanV
  Astra J GTC 2.0 CDTi suspension entlio 3 0 30:th-May-2018, 08:32:57
Last Post: rlievens
  MOT Fail - Broken Rear Coil Spring marcus01 13 0 9:th-Apr-2018, 13:20:38
Last Post: rlievens
  Astra J Rear Bike Rack Rlewis33 2 368 1:st-Jun-2017, 09:19:49
Last Post: Jerry
  Rear fuse box Astra sri 2014 bluenose50 2 385 18:th-May-2017, 22:27:39
Last Post: Jon_es
  Best oil for 2.0 cdti chrisb2511 12 2,525 28:th-Dec-2016, 11:18:44
Last Post: stigeye
  Rear wiper removal Dannydyer 36 6,105 6:th-Jul-2016, 14:36:53
Last Post: J1ODYA
  Fitting Electric Rear Windows THEHITMAN 4 1,030 29:th-Apr-2016, 07:48:57
  GTC Rear Vauxhall Badge KRISGTC 3 1,129 10:th-Apr-2016, 11:42:13
Last Post: J1ODYA
