| Welcome, Guest |
| Latest Threads |
Two heated seat part numb...
3:rd-May-2026, 10:07:20
intro
2:nd-May-2026, 17:42:23
owners manual
2:nd-May-2026, 17:37:41
tailgate r/h cover
2:nd-May-2026, 17:36:45
Clean DPF - O2 sensor loc...
24:th-Apr-2026, 17:31:05
| Cd500 help |
Posted by: Jpbroad1970 - 14:th-May-2017, 19:23:32 - Forum: Astra-J/GTC
- Replies (2)
Hi, does anyone know if you can use the cd500 control panel on a dvd 800 both from astra j
John
| Multi function display screen |
Posted by: John 1944 - 14:th-May-2017, 15:33:10 - Forum: Astra-J/GTC
- No Replies
Hi there. Does anyone have a 13 plate Astra j vxr multi function display for sale. I only need the trim and it's for the older LCD one many thanks in advance
| Diameter of front discs |
Posted by: dutton84 - 14:th-May-2017, 10:38:53 - Forum: Request for information
- Replies (6)
Hello
Euro car parts are doing up to 55% off today, so I'm after buying front and back discs and pads. I can get the lot for £156.46!
Problem is I'm unsure of the diameter of the front disc. Euro car parts say that there's 2 types 300mm and 321mm I've just measured mine and they're 280mm!
Cars a 1.6t 2010
| Intermittent starting issue? |
Posted by: Boroboy - 13:th-May-2017, 22:19:40 - Forum: Astra-J/GTC
- Replies (10)
I've owned my 63 plate 2.0cdti elite auto for around a year now, this being my 4th J.
Anyway for around a year now this one has suffered from a very intermittent starting prob.
I went to start the car today, as you do. Just before setting off to work. Sat in my car, gearstick within the parked position (being an auto), turned ignition key on to start it, nothing. Turned key off, then back on again, but within the on, not starting position. Clocks did their checks, turned it on, nothing again. Turned the key off again. Thinking about how I'm going to get to work. Waited around 10 seconds, turned key on. Fired straight up. Used it all day, today. No issues. This problem has probably occurred around 6 times over the duration of ownership. Last time, being around 3 months ago. Very intermittent. Going to check battery voltage tomorrow with my multi meter.
I've never had this problem with any of my previous J's. 1.6, 1.4t, 2.0cdti, all being manual versions.
Anyone else had similar issues? Solution?
| blowers intermittently working |
Posted by: micko - 12:th-May-2017, 12:55:40 - Forum: Electrical
- Replies (1)
ok guys my blowers work with ignition on but when i start the car they go off 90% of the time? sometimes come back on
if i have been driving for a while,when they go off the red lights on the controls all go off,when they work they work on all speeds
air con works ice cold ect,checked fuse seems ok,check wire to blower all fine,do you think it could be the panel?
